Demonstration of ABS vs non-ABS
Platinum
GAH... I likely SNIPED it from YOU, then. Profuse apologies!
I came across it on my machine while hunting another pic and giggled, obviously forgot where it came from.
Hehehe... well, it was way back in August. :smile:
Well then! That was eons ago. My Oldtimers' disease kicked in.
It surely was. There have been zillions of postings here at the forum between then and now. :rolleye:
Besides, I can never remember where I got something. Sometimes here and sometimes FacePlant… sometimes elsewhere.
Not sure about the post count but the TIME past is more the issue. I can put a tool or other bit of kit down on a bench, and two minutes later it seems to have grown legs and run to Oz or some other dimension. Takes half an hour for it to mystically re-appear in some other space. It's diabolical, I tell ya!
That is a phenomenon seen especially with tape measures and utility knives. I've been known to scatter both so there is usually :smile:wink-new:smile: one to be found.
The renegade 10mm socket that fell and went to the "Twilight Zone"!
That is why it takes so long to finish these restorations. 50% of the time is spent looking for tools 50% of time trying to remember what you were doing before you stopped to find the tool.
That is my excuse. Then there are parts that walk off and hide in dark corners.
David
Even worse - the screw that falls into limbo, only to end up in your right front tire. I dropped a tiny headlight rim screw two days ago and never did find it on the concrete garage floor.
I've found that one of Newton's Corollaries is that the tool or part dropped rolls/bounces/ricochets to the most inaccessible and darkest area under the car. Always just out of arms' reach.
Yep - and if it's made of steel, it'll get wedged between two other, inaccessible, steel parts, where a magnet is useless.
(Happens when you're restoring ancient church organs too ...)
Ever walk into the kitchen and stand there wondering why you went in there in the first place?
It's like the Plinko game on The Price Is Right. You listen to it hit various things on the way down, and just hope the last sound you hear is the part hitting the floor. Then there's the sinking feeling when it bounces a couple times and stops, and you have no idea where it landed. I've spent more time that I care to admit hunting for dropped hardware. Can't start the engine until all the metal is accounted for.....
One of my shop owner pals has a small roll-cab tool box stocked with various sockets, wrenches and other tools found in customers' cars, wedged in normally inaccessible parts of the engine bay. Calls it his collection of "cow tools".
I have quite a few tools I "acquired" under the hood of customer cars. Mercedes is a pretty good brand for finding other mechanic's lost tools because they have full belly pans under the engine. Anything dropped will likely rattle down and sit on the pan. The tool gods have delivered some nice 1/4" ratchets and multiple sockets, screw drivers, pry bars, picks, etc.
Unfortunately, the tool gods are cruel and taketh away about as much as they giveth.
We call that "Pondering the Hereafter". Translation: Wondering what I am here after.
