tallguylittlecar
I am in the process of Degreeing the reground camshaft I got from TS Imported and I have a few questoins.
The information that came with the card is as follows:
TR Torque cam specs
intake - opens 20 degrees BTDC; closes 60 degrees ABDC
Exhaust - opens 60 degrees BBDC; closes 20 degrees ATDC
Checking Clearance is .010"
Cam lift - .290", duration is 260 degrees, 110 degrees centerline
I have found the True TDC using a piston stop, and now I need to dial in the cam. I just want to make sure I am doing and reading this information correctly. The way I read this I should be at 20 degrees BTDC with my number two push rod reading .010 of lift off my dial indicator. Any help or advice is much appreciated. I want to make sure that this is %100 percent correct before I go any further.
Thanks,
Derek
TR Torque cam specs
Thanks,
Derek
