Degree camshaft center lobe method
Johnnyhealey
When do a camshaft degree with a dail indicator for the intake center lobe method. Is that’s performed on the number one cylinder with gears set as pictured in the shop manual with some valve overlap. or rotated 180 degrees when number one cylinder pops your finger and both valves are lose
