Having a business that regularly serves the needs of Triumph owners(and me too) I have had trouble getting
a quality replacement master cylinder from my regular suppliers. The symptom is that it is very nearly impossible to bleed
the air from the system regardless of time spent or the expertise of the tech performing the job.
Disassembly of the new units reveals that the tiny waffle washer in the end valve of the plunger is not there. There was a good
reason the factory had it in there in the first place. Some kid in Taiwan is not putting them in and these (IMHO) defective
units are all over and the distributers say they are just fine if you only get some engineers to bench bleed and work for 3 and a half days
eventually most of the air is gone.........I call DINGO ON THIS! The cost of this tiny washer is miniscule and the time I have personally spent
on just one master, trying in vain to do a job that should take minutes, is sad.
If you have to buy a new master for a tr3, get a kit or cannibalize the old one to get the waffle washer or you will wish you had.
MD(MAD DOG)
MD(MAD DOG)
Hi Guest!
