Deer Roping
kyreb1862
This is an actual letter from someone who writes and farms:
For those of you who hunt a deer, want to pat a deer, or anything in
between ... this is too funny! Names have been removed to protect the
stupid...
'I had the idea that I was going to rope a deer, put it in a
stall, feed it up on corn for a couple of weeks, then kill it and eat
it.
The first step in this adventure was getting a deer. I figured
that, since they congregate at my cattle feeder and do not seem to have
much fear of me when we are there (a bold one will sometimes come right
up and sniff at the bags of feed while I am in the back of the truck not
4 feet away), it should not be difficult to rope one, get up to it and
toss a bag over its head (to calm it down) then hog tie it and transport
it home.
I filled the cattle feeder then hid down at the end with my
rope. The cattle, having seen the roping thing before, stayed well back.
They were not having any of it.
After about 20 minutes, my deer showed up -- 3 of them. I picked out a
likely looking one, stepped out from the end of the feeder, and threw my
rope. The deer just stood there and stared at me.
I wrapped the rope around my waist and twisted the end so I
would have a good hold. The deer still just stood and stared at me, but
you could tell it was mildly concerned about the whole rope situation.
I took a step towards it...it took a step away. I put a little
tension on the rope and then received an education.
The first thing that I learned is that, while a deer may just
stand there look at you funny while you rope it, they are spurred to
action when you start pulling on that rope. That deer EXPLODED.
The second thing I learned is that pound for pound, a deer is a LOT
stronger than a cow or a colt A cow or a colt in that weight range I
could fight down with a rope and with some dignity. A deer - I had no
chance.
That thing ran, bucked, twisted and pulled. There was no
controlling it and certainly no getting close to it. As it jerked me off
my feet and started dragging me across the ground, it occurred to me
that having a deer on a rope was not nearly as good an idea as I had
originally imagined.
The third thing I learned, the only upside, is that they do not
have as much stamina as many other animals.
A brief 10 minutes later, it was tired and not nearly as quick
to jerk me off my feet and drag me when I managed to get up. It took me
a few minutes to realize this, since the blood flowing out of the big
gash in my head mostly blinded me. At that point, I had lost my taste
for corn-fed venison. I just wanted to get that devil creature off the
end of that rope.
I figured that if I just let it go with the rope hanging around
its neck, it would likely die slow and painfully somewhere.
At the time, there was no love at all between that deer and me. At that
moment I hated the thing, and I would venture a guess that the feeling
was mutual.
Despite the gash in my head and the several large knots where I had
cleverly arrested the deer's momentum by bracing my head against various
large rocks as it dragged me across the ground, I could still think
clearly enough to recognize that there was a small chance that I shared
some tiny amount of responsibility for the situation we were in. I
didn't want the deer to have it suffer a slow death, so I managed to get
it lined back up in between my truck and the feeder - a little trap I
had set before hand -- kind of like a squeeze chute. I got it to back in
there and started moving up so I could get my rope back.
The fourth thing I learned... Did you know that deer bite? They do! I
never in a million years would have thought that a deer would bite
somebody, so I was very surprised when I reached up there to grab that
rope and the deer grabbed hold of my wrist.
Now, when a deer bites you, it is not like being bit by a horse
where they just bite you and then let go. A deer bites you and shakes
its head, almost like a pitbull. They bite HARD and it hurts. The proper
thing to do when a deer bites you is probably to freeze and draw back
slowly. I tried screaming and shaking instead. My method was
ineffective.
It seems like the deer was biting and shaking for several
minutes, but it was likely only several seconds. I, being smarter than a
deer (though you may be questioning that claim by now), tricked it.
While I kept it busy tearing the bejesus out of my right arm, I reached
up with my left hand and pulled that rope loose.
That was when I got my fifth lesson in deer behavior for the
ay-- Deer will strike at you with their front feet. They rear right up
on their back feet, strike right about head, and shoulder level, and
their hooves are surprisingly sharp.
I learned a long time ago that, when an animal-like a
horse-strikes at you with their hooves and you cannot get away easily,
the best thing to do is try to make a loud noise and make an aggressive
move towards the animal. This will usually cause them to back down a bit
so you can escape.
This was not a horse. This was a deer, so obviously such
trickery would not work. In the course of a millisecond, I devised a
different strategy-- I screamed like a woman and tried to turn and run.
The reason I had always been told NOT to try to turn and run
from a horse that paws at you is that there is a good chance that it
will hit you in the back of the head.
Deer may not be so different from horses after all, besides
being twice as strong and 3 times as evil, because the second I turned
to run, it hit me right in the back of the head and knocked me down.
Lesson six... Now, when a deer paws at you and knocks you down, it does
not immediately leave. I suspect it does not recognize that the danger
has passed. What they do instead is paw your back and jump up and down
on you while you are laying there crying like a little girl and covering
your head. I finally managed to crawl under the truck and the deer went
away.
So now I know why when people go deer hunting they bring a rifle with a
scope... so that they can be somewhat equal to the prey'.
Yes, I have a friend who bow hunts, twice he forgot a knife that I know of and a two broken noses.
haha very funny story.
He's probably looking forward to hunting season with a vengance... literally.... :devilgrin:
Methinks he is going deer hunting with the nose gun out of a Cobra gunship! :laugh:
:lol: I'm in tears.
Distance can be your friend.
qNPpYzY" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
Then again, you could sell the gun and train a golden eagle. <span style="font-weight: bold">This is really impressive.</span>
JAooWhs" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
Now wait one COTTON PICKIN MINUTE.The dialogue is in French and the guy is speakin English underneath.
Sumpin ain't rite here!
Where did you get this?
Wait a minute...
I know an eagle is bigger than a parakeet but...
Isn't a deer significantly larger than an eagle?
I guess it'd depend more on how hungry the eagle is... :shocked:
I got it...
It's one of them itty-bitty French deer.
(About house cat size on longer legs)
Compound bow: $300
Camo suit: $200
Razorpoint arrows: $125
Your buddy holding the camera while a giant buck kicks the stuffing out of you: priceless
"Ya can't push w/ no rope"
(Saying of a friend of mine after a similar incident)
It means that prey will eventually stop running BEFORE they are unable to fight.
(He was near starving in a remote area and managed to snare a wild turkey that struggled madly to get away...Then turned & beat the crap out of him before he finally managed to kill it)
(And eat it)
WhatsThatNoise said:
Wait a minute...
Gold and Bald Eagles have been known to feed on young deer and goats, as well as other birds of prey aside from their usual food sources. The body lengths of these birds can exceed 3 feet and the wingspans can exceed 7 feet. Make no mistake, these are very large birds. The Golden Eagle, Bald Eagle and the California Condor are the largest birds of prey in North America. I've seen Golden Eagles whose wingspan covered an entire lane of the roadway where it was lunching on some road kill. There are also Bald Eagles here around Fort Collins that make regular meals of Canadian Geese during the winter months.
A customer of mine told me of a guy who decided to do something similar. He jumped out of a tree stand onto the back of a doe. What he thought would be fun almost killed him.
He hadn't been regarded for his intelligence before the stunt, and this only confirmed everything.
In our neighborhood several years ago a deer was hit by a car on the nearby street. The wounded deer dragged itself into the neighbor's driveway. The neighbor called the police. The policeman not wanting to shoot the deer for fear of a ricochet decided that stabbing it would be the better solution. Well the sight was rather gruesome, but the cop managed to finish the deer off.
Warning this has MORE than a little bit of "colorful" language...(I hope I'm not breaking rules, but this IS funny!!)
Moderators: judgement call!!
:devilgrin:
