Joel, everything from Marvel, to ATF, or even 20W50 will work. The actual factory recommendatation was for essentially the same oil you are running in the engine. In the '65 I have that lives north of you, I run 20W50 in both the engine and the carbs, and it seems to work just fine. It's on the west side of the Sacramento valley, so sees the same climate as Salinas.
Oil that is too thin may allow the pistons to rise too quickly, creating a temporary lean condition on acceleration. If you get this, try different oil. I actually had one set of carbs that used different oil in each of the pair, to match piston movement rates.
Jeff
