Dash Refinish Progress
jjbunn
At the request of Brosky, some photos of the dash and how I'm refinishing it.
As removed from the car:
Detail showing the cracking varnish, and "HAZARD" "BRAKE" lettering:
After stripping off all the varnish, using a heat gun and carefully prying with a putty knife. Not too bad: some strips of the veneer came off, e.g. to the left of the hazard switch:
After filling and touching up with "walnut" latex wood paste (upper piece in photo), rubbed along the grain with 320 grit sandpaper, cleaned and just after applying a first stain with "Red Mahogany" (glove box).
After the whole piece has been stained (two coats) and dried:
After applying "HAZARD" and "BRAKE" labels, printed in white letters on transparent tape, on a Brother label maker, then a first coat (just applied) of polyurethane clear gloss varnish.
This was rubbed down again with 320 grit, allowed to dry, and a further coat applied, which is now drying. I intend to apply several more coats, until the surface is as smooth as possible.
This is excellent - seeing all these steps and gradual progress. Thanks for taking the time to post all the details.
Tom
Hey, nice job, Julian!!
Keep the progress photos coming.
great idea about the label maker, Im going to do mine this December during my christmas break. I was wondering how to replace the label. Please give us feed back on how the final products lasts
I was thinking of using GunStock refinishing, from Birchwood Casey
Nice work, Julian. Triumph ownership apparently suits you. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Another "source" for matching the lettering is to take photos/measurements to a good sign shop with a vinyl cutter and they can make "RTA" (Ready To Apply) lettering from thin white vinyl.
Julian,
I have a couple of parts for you, if you want them? A good working Lucas headlight switch and a wood TR shift knob.
I know you have your hands full trying to locate parts for your car so if you can use them, PM me your address and they're yours.
I'm not trying to insult you with my throw aways, but I'm honestly only going to otherwise throw them away.
Looking good. Are you sanding in between coats?
Looks like you might have gone to brush rather
than spray finish, huh?
When you reach for the final piano finish,
consider this/these product(s).
They really worked well for me.
A powder that acts like sandpaper. First one, then
the other. Product literature will tell which to
use first.
https://www.pilgrimsprojects.biz/pumice.html
Good work and keep posting, Julian.
