I only had to get the air out of the brakes so that I can bring my car in for inspection on Sunday (a regular business day here). Poured in a bit of brake fluid, and it came shooting out of one of the rear cylinders. Luckily I had a spare, swapped it, got the air out and when to look for leaks and fluid is dribbling out THROUGH one of the pipes. It kind of looks like the pipe was dented so hopefully the problem isn't rust. I guess I will cut the end off and put a new flare in. I should have enough pipe to make it work at least temporarily. Still I am going to have to replace the brake pipes soon.
I also still have a small leak from the oil pan, coolant coming up from one of the head studs (head gasket??? hope not, maybe it will stop when I re-torque the head bolts), and a small dribble from one of the new freeze plugs. However these problems shouldn't hold up inspection so I should be able to drive a bit before winter starts. The car hasn't driven in more than 2 years.
