I'm sure somewhere in the vast archives there is probably an answer to this but I'll try anyway.
Recently I've been noticing the B running roughly. I cleaned everything up electrically, put ATF in the SU dampers (HS4's), new air filters. To no avail. Today I took the cleaners off and noticed that when I throttled that the front carb damper piston was not moving as much as the rear, meaning the needle travel was not as great giving a leaner mixture in the #1 and #2 cylinders (I suppose). Any ideas why this might be? The needles are the self centering kind.
