I think I found the source of my constant tapping, despite repeated re-setting of the .010 clearance. One of my lifters, valve 5, is really smacked up bad, with a very noticeable concave underface. Another lifter is knocked up a little but not much.
The lifters were new in 2004, and since then only 20,000 miles on the car.
I do not believe I did a proper cam break-in back then.
What would cause one lifter to be so damaged? I'll replace the cam, of course, but I'm concerned the pocket where the lifter sits may be damaged, or maybe the cam bearing in that area.
Does this happen sometimes just do to unpredictable binding in the slot? Should I just replace the lifters and cam and go back to driving, or do I need to pull the block and get more serious here?
