Brosky
I received my cylinder head yesterday as it literally bounced it's way into my life, thanks to the UPS driver actually "dropping it off" at the rear door. My wife heard the bang and went out to see what had happened. Fortunately, he dropped it on the valve spring side and I don't think anything was damaged.
I'm not about to take any chances, so I delivered it to a good local machine shop, (Motor Tech in New Bedford, MA) who does heads for Triumphs regularly, to be checked and tested.
I measured the head thickness in several spots and came up with 3.540",which is thicker than it was advertised on eBay. I asked Bob at Motor Tech to check for any cracks first, measure the thickness and then the check the deck surface before I decide what I want to do.
I'm thinking about Richard Good's chart and I'd like to stay at about 8.0-8.5 to 1 compression. That will give it a bit more zip, but no major dieseling or pinging issues.
https://www.goodparts.com/tech_docs/TR6_Compression_Ratio.html
I asked Bob to quote the following:
Take another .050" off of the deck if it can stay at 8.0 - 8.5 to 1 compression
New valve guides & seals
New hardened seats and grind valves accordingly
New freeze plugs
Shim and set spring height and replace weak springs and retainers.
CC combustion chambers and remove any sharp edges
Anyone have any other thoughts about machine work, while it's there?
This is what I'm starting with, so it doesn't look too bad so far.
New freeze plugs
