Cylinder Head nut torqueing pattern
Michael Oritt
I do not have a shop manual available and would like to either access online or receive by email at: awgertoo@aol.com an illustration (page scan, photo, document, etc. etc.) showing the pattern for torqueing cylinder head nuts.
Best--Michael Oritt, Elva Courier w/MGA 1500
Michael, a PDF was sent. HTH!
Biggest thing to remember is inside - out, meaning start in the middle and work your way out, this applies to any motor.
Start out with just snugging everthing, then about half the required torque then split the that again between what you just torqued to and the final torque, then go to the final torque number, I always double check between each torque as well. make sure everyhting is oiled and never use split lockwashers anywhere on the head.
Nothing more to add except remember to back your torque wrench down to zero when finished. NEVER store it set to a torque setting.
/ubbthreads/images/graemlins/lol.gif Now, Scott....how do you know that? hehehehe
