Willie_P
So when stripping my car, I took the old shock links off and "cut out" the rubberized bushing/glue material that holds the threaded stud in place. The stud that connects to the lever shock arm. I did not fully realize this was not a replaceable bushing. You have to buy a new shock link.
So, I was thinking:
1) is there a recommended epoxy or adhesive that is good for metal to rubber or polyurethane? something that creates a permanent bond that still has flexible qualities?
1a) because I see that my poly suspension bushings fit nicely in the circular hole in the shock link. Then I could put some locating washers on the each of the outer sides of the newly seated bushing and then run a threaded stud thru the bushing to connect to the shock lever arm.
1b) the epoxy would help fill a couple mm gap btw the inner diameter of the link eye and the outer edge of the poly bush.
2) ...or, does anyone have thoughts on using a solid steel bushing (instead of the poly above)? The logic here is that the steel might offer better performance/handling qualities than the poly?
3) finally, is there just a straightforward repair of the OEM set-up? (aside from buying new shock links).
thanks! ...hope someone can offer a creative offer.
So, I was thinking:
