TR6 Crankshaft pully fell off /TR6/more info
SCguy
On the way to my first car show with my TR6 the bolt that holds the fan extension and fan back out! The fan punctured the radiator and I noticed coolant spilling out my back while on the freeway going 70. I caught things right away and the car didn't overheat.
I did make it to the show with my TR8. I'll post pictures later. Over 200 british cars made it!
Ok here's more information... It looks as though I have a later style fan on my early TR6 engine This means that the later fan probably used a different bolt. One with a smaller head. In my last picture you can see that the bolt I have fits down into the fan adapter and can not be tightened. I think the mechanic who installed the fan got it as tight as he could but also added a little JB weld where the fan extention meets the pulley. So I guess my options are to buy an earlier 7 blade fan and hardwear or source a later bolt (assuming they are actually different.
I guess I just need to get my radiator recored.
Anyone have any insight that can confirm what I think is going on?
Larry, doesn't the fan extension bolt on first and the two small studs keep it from rotating. I used some red Loctite and a lot of torque. I may well have used an impact wrench.
Anyway, the fan adapter bolts to the extension afterwards. You have a latter style fan, but that shouldn't matter.
