Crank
DNK
Anybody in the SE have an extra TR6 crank. Have a friend in need.
Todd, fixed above post.
Thanks for the heads up
It's for a guy in FL.
I see your email is in your profile. I'll send it to him to contact you if that is OK
I have a .020 under with bearings for a '76 TR6 in excellent condition... Changed the crank that truned out to be a flywhel issue.
What year is the TR6 in need. There were two different cranks used and they have to be matched to the appropirate flywheel. Early cars had a longer crank and a different flywheel than the later cars. Cutoff was in '71 I think but that is what accounts for the two different weight flywheels as well.
Shawn, yeah, I know. It's a later car so I didn't specify as most here are that way
Big 6, will keep you in mind if Marv's doesn't work out.
