crank shaft thread die
John Loftus
Hey Healey-holics,
I'm searching round for a 1" -20 tpi rethreading die for cleaning up the crankshaft threads where the dog nut theads on but having trouble finding one through McMaster, Rutland, etc.
Anybody have one to borrow/loan/purchase or can steer me in the right direction?
As an alternative, would you suggest using a 20 tpi thread file or is the rethread die the only way to go.
Cheers,
John
Hi John,
I believe a 1" x 20 thread would be a "Unified National Extra Fine" thread.
You could see a listing here:
https://www.newsontool.com/05_c08.html
The die & a handle (stock) to turn it would be very costly, as would even a thread "chaser".
A standard 20 TPI thread file would likely have a 60 degree profile, the UNEF would be 60 degree. I think careful work with a regular three corner file would straighten the threads.
I have split one side of a matching nut to allow it to expand enough to get it started & then used it as a die, sometimes with lapping compound. Not fun, not easy, & very slow.
If things are not screwed up too badly, the file might do the trick.
Maybe you can borrow something locally or take it to a machine shop.
Glad it's not mine. You have my sympathy.
John Loftus said:
Hey Healey-holics,
Cheers,
John
John,
British Car Specialist in Stockton, Calif. have them in stock. Not cheap!
Patrick
Hi John,
Give the guys at Allen Bolt a call. I’m 95%ish sure they would have what you need. I bought a left hand die from them for the door check strap bolt.\
Allen Bolt
Hi Dave,
Luckily things are not screwed up too badly. Shortly after buying the Healey I heard a strange noise from the engine compartment. Turned out the Dog nut had worked loose and was rattling around. It didn't fall off because the frame cross member kept it on but it did screw up the threads on the nut(I guess the nut threads were softer than the crank threads). I used the dog nut off my spare motor and it worked fine for several years. Now that the motor has been rebuilt I noticed the threads look a bit beat up on the crank and the dog nut needs to be replaced. I just want to clean things up so I don't have any problems.
Speaking of extra fine threads. I asked a buddy who rebuilds suspensions for mountain bikes what they use for the old style 1" steerer tubes and it's 24 tpi.
I appreciate all the leads (thanks guys!). Turns out there are several sources that carry the die for around $25 to $35 so I'll just order one up and have it if anyone needs to borrow it.
Cheers,
John
John Loftus said:
Hi Dave,
Cheers,
John
Hi John,
I had a prices given to me up to $135.00 for the die. Could you share the sources for the cheaper dies?
Thanks,
Patrick
Hi John:
And this time when you put the new nut on be sure and use an Impact wrench.--Keoke
GregW said:
Hi John,
They can get one .. $65
Rutland Tool has them for $35.98 (part #21080434)
and as Anthony pointed out, Victornet.com has them for $27.50
(item rd-1-20 -d = 1"20 hs die)
and for about $10 one can get a hex adapter that the 2" die will fit into or get a 2" die handle.
Cheers,
John
Keoke said:
Hi John:
Hi Keoke,
There's this guy who lent me a 1 11/16" standard socket. I'm sure he wouldn't mind if I used it with my impact wrench. /bcforum/images/%%GRAEMLIN_URL%%/hammer.gif
Cheers,
John
John Loftus said:
Keoke said:
Hi John:
Hi Keoke,
Cheers,
John
Me too Dave, I didn' have to do no neckin or nothin and I don't need no steeking adapter either. But then some folks just gotta make a moutain out of a mole hill.--Keoke-- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Cheers,
John
Sure John,
I’d only ask that you don’t hook it up to the air compressor.
GregW said:
Cheers,
John
Sure John,
Yep Greg, all he needs is the Jacobs Electric.---Keoke- /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
What's the point of having a garage full of cool tools if you can't make up reasons to use them (my wife has been led to believe I can't survive without them)?
Randy /bcforum/images/%%GRAEMLIN_URL%%/savewave.gif
Fist time I get up that way I will be sure and have a long talk with your Missus.---Keoke---- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
