MGB Courtesy light for 78 mgb
G
Need to replace mine, but having a challenge locating one. Moss and LBC do not have available.
Suggestions?
Try Victoria British and Proper MG for new repro parts. There's bound to be lots of people (including me, if I can find it) with used ones if you're in bad need of one that at least works. I replaced mine a couple of years ago with a brand-new one and they work great. The plastic parts inside wear so that the contacts don't work as "positively" as they should. My old one worked but the action was mushy and didn't always stay ON when I wanted it to.
Good luck
My 78B’s courtesy didn’t work either when I first got the car. Turned out to be three different things.
1) The bulb had long since died and needed replacement. I always try the easy stuff first. /ubbthreads/images/graemlins/wink.gif
2) The courtesy lamps contacts had some corrosion on them. I pulled the entire assembly and gave it a good cleaning with some electronic contact cleaner (from Radio Shack) and a soft wire brush. Put it back in and the light would work fine when you manually turned it on.
3) But this courtesy lamp sill wouldn’t come on when the doors opened. Turned out that both door switches had some old paint & corrosion that wouldn’t allow a good contact. All I did was clean them up using some contact cleaner, along with some fine emery cloth and every thing was working great.
Also I had the same problem with the courtesy lamp in the truck (boot). Basically follow the same steps for the interior courtesy lamp. Actually – corroded contacts & burned out bulbs turned out to be a common scenario throughout the first few weekends I spent chasing down Lucas Electrical Gremlins.
thanks so much. Ordered from Proper MG. about 27 plus shipping. Seems fair. Not is stock, but will get in 3 weeks.
Unfortunately, the plastic parts which hold the contacts have disintegrated here in the Florida heat.
