Stewart
Ok as I bring back my B the deeper I go the more stuff needs to be done.
I fixed the problem I had with the carb and got it to run briefly which brought to light more problems.
When it fired up it ran quite rich at idle which was expected but one cylinder was not firing. Confirmed by removing the plug wire. Previously I had removed the wire and plug in order to get a new set of plugs. At that point I went ahead and changed the plugs checked all the wires and went to fire it up again. It started right up but quickly lost power and was never responded to throttle input. Pulled the plugs and they were wet. It has not started up since but does now hint at firing.
I was thinking for this problem new wires cap and rotor but if anyone has any suggestions I'm all ears.
Problem 2.
Temp gauge appears to be working backwards. Was working properly prior to pulling the carb off and rebuilding it. Since everything was reinstalled its been backwards. Any idea on what I did wrong or did Lucas strike again.
Thanks for the help.
Problem 2.
