Sorry, I know this is very basic, but I just want to make sure. When I set the distributor, I get it close, and tighten the center clamp bolt. I then do the finer adjustment by tightening the two side bolts. Sound correct? I used to tighten the two side bolts that go into the block and then tighten the clamp. It seems like that way would prohibit the clamp from getting very tight since the clamp is being held in place. Your help is greatly appreciated.
Kevin
Kevin
