On most cars if you put put a finger in the diff fill hole and the oil level is just below the fill hole your good to go. Is this correct for the TR3 or is it possible to overfill the diff? I just topped it up with the intent to monitor the seal leak. If it's not too bad I would like to postpone changing out the seal until Fall. Don't want to overfill and make the situation worse.
Karl
Karl
