Richard_Brown
I just ran across this and thought others might like, I an restoring my whole fuel line and tank and about to put it all back together, was shocked that the fuel lines never used any clamps, granted there really is not much pressure, but still, its fuel. I found out when I was blowing air from the fuel pump through to the back of the car where it connects at the tank, I found the line was clogged on the last section ( before the tank) because the line popped off at the rubber "connector".
I find this a bit disturbing that it could be so easy to pull the fule line apart with hands,( insert gangster movie clip here where they cut fuel line and send a match to the puddle of fuel) so I think I am going to install clamps
https://www.macysgarage.com/myweb6/fuel_hose_clamps.htm
