My generator is charging fine. I did the wire the terminals together and attach volt meter in between test. The problem seems to be the control box. I cleaned the points and manually shut them. They stayed shut and voltage was going through them with the dash light out. The problem is they will not open unless it is done manually. I swapped control boxes and manually closed the points. They stayed close for awhile with the dash light out and then opened on their own. My battery voltage at that point measured 14.5 volts which is charged. I have not taken the car out with the light on to see what happens. Not really sure what's going on. Any thoughts?
Thanks, Donnie
Thanks, Donnie
