jerrybny
I posted about a month ago about my Temp gauge being at about 3/4 mark when its hot and humid. Many suggestions were made. Here is what I've done:
1)New Temp Sending unit 2)160 degree Thermostat
3)Checked timing-OK 4)Balanced Carbs and adjusted
mixture
5)Installed 185 degree thermoswitch for 16" electric fan
6)Check vavlve clearances - OK
7)Replaced Temp Gauge with spare
8)Replaced voltage stablizer with spare
9)Checked water pump belt tension - OK I can see the water flowing once the thermostat opens
I used an infrared Thermometer and the fan is coming on when the upper radiator hose is about 185 degrees. It stays on for about a minute and then shuts off. It continues to do this as long as the car is running. The temp gauge is between 1/2 and 3/4's mark when the fan comes on. I haven't seen the temp go above 195 on the upper hose or the radiator.
So after that long winded explanation I am wondering if I have missed checking anything or is everything ok. It just bothers me that the gauge is sitting between the half and 3/4 mark when idling. When I am driving it comes down to just a hair over the half way mark. Am I driving myself mad over nothing??
Has anyone else with a TR6 ever checked the temps at different locations? Such as the exhaust manifold, block, etc. If so I would be curious what they were so I have something to compare against. I want to thank everyone who has responded or is going to respond.
mixture
