Got in a new coil and ignition wires for the Tunebug. I had expected them to be pre-made, but what I got was a little kit with a length of wire and 4 ends to clip over the plugs. My cap is the side-entry sort, so I can see how that end attaches to the plug wires, and the little plug caps seem to screw into the wire.
Now the coil connection is a little different. This is a screw-in type coil, and the coil came with a little screw cap and a small washer-type thing. How do I make the connection at the coil end with those bits and the wire?
My old coil wire was just taped up and stuck into the top, so its not of any help as an example.
