Winghealey
I've just had mu DM6Arebuilt ..in that process the electronic ignition was removed and points put back in.
I had the two wires from the distributor labeled..and now starting from scratch...
there is now just the one terminal on the distributor ....I have positive ground
anyone able to give me a simple instruction on how to hook up
The only wire I have connected so far is from the sport coil positive to the clamp bolt
1960 Austin Healey 3000 MK1 tricarb/center shift conversion
Hi Guest!
