robert_ellison
I just installed an electric fan and ran the hot wire to a fuse block on the right side of the car. The closest source of power for the fan is the 2nd hot terminal on the coil ( white wire terminal). If I connect the power to this 2nd terminal will this create problems?
The benefits are:
I am close to the coil and wont have to run a wire all the way across the firewall to the main fuse block.
The coil is switched as will be the fan so it provides an on/off controlled by the key.
The benefits are:
