Confirm Diagnosis
kyreb1862
When I press hard on the brake pedal in my 77B the idle speeds up. Am I correct in assuming that my brake booster has gone bad?
Regards John
Hmm, that is a good question. It could be that the booster is gone, but it could also be a leak, maybe at the valve on the booster.
I can't recall exactly how to do it, but I know there is a test to see if the booster holds vacuum (from a pump or gauge like a Mitivac).
check valve or booster. A vacuum pump is the best way to isolate which. It ~sounds~ like the check valve is the culprit.
