Computer question
jlaird
Does anyone know how to get my microsoft browser to open all windows full screen mode automaticaly?
Somehow I have forgotten this trick.
Automatically, no. But if the last window you closed was full screen, the next one you open should also be full screen.
Oh, will watch for that, and yep I know about the control and shift bit on new links.
If you create a shortcut, then right click on it and select the 'shortcut' tab above, you'll see a field that says 'run'. It will usually default to 'normal window', just click on the drop down togle and select 'maximized'.
Bear in mind it has to be a shortcut and not the icon from where the program is launched.
Or, as Steve mentioned, you can, from a normal screen, use the arrow at the bottom left corner of the screen and drag it to full size, then when you open it next time, it will be that same size.
Ahh, drag it, thats what I remember, thanks guys.
