DrEntropy said:
The hardware should handle a 64 bit OS just fine. The reason the computer came loaded with 32 bit is probably compatability with software. Win7 home edition doesn't have the XP option mentioned above, so if you have programs that don't like 64 bit, you're stuck.NutmegCT said:Doc - I'm puzzled that Paul's machine came with 32 bit o/s installed, if the cpu supports 64 bit.
Any ideas? Maybe his m/board doesn't support sufficient memory for a 64 bit advantage?
Tom
PAUL161 said:OK, I'm up and running 64 bit. No compatibility issues so far. Computer seems to be running a little faster, but it might be my imagination. So far everything's working as it should. :thumbsup: PJ
NutmegCT said:PAUL161 said:OK, I'm up and running 64 bit. No compatibility issues so far. Computer seems to be running a little faster, but it might be my imagination. So far everything's working as it should. :thumbsup: PJ
Hey - great news. When you put on the 64 bit Win7, what applications (Word, Browser, email, business apps, etc.) are/were you running? have you tried them all?
I'm still puzzled that your machine came with 32 bit installed, even tho' it's technically capable of 64 bit. Unless you installed your own apps, and are just lucky they're running in 64 bit mode?
Thanks.
Tom
And still you got a MacBasil said:My new iMac is 64 bit and I installed 64 bit Win 7 (I use bootcamp so I can have moth Win 7 and Mac OS on the same HD). <span style="font-weight: bold">I really like Win 7 so far</span> (compared to XP and (ugh) Vista). Seems MS did their homework this time.
GregW said:And still you got a MacBasil said:My new iMac is 64 bit and I installed 64 bit Win 7 (I use bootcamp so I can have moth Win 7 and Mac OS on the same HD). <span style="font-weight: bold">I really like Win 7 so far</span> (compared to XP and (ugh) Vista). Seems MS did their homework this time.![]()
