Recently performed a compression test as part of maintenance. All cylinders read between 180 and 182 psi. The manual states compression should be 120 psi. The tester instruction claims that if the reading is considerably higher, it may indicate carbon buildup. Dieseling does occur when shutting the car down. I've read that dieseling also indicates carbon buildup. Is this reading problematic and what is your experiences when performing a compression test?
