Tabcon
I've been doing all the pre-tuning I can do without actually being able to run the car down the road, and after a compression test, all the cylinders are close to being within 10% of each other with the exception of the number 3 cylinder which is higher then the rest.
The readings are:
No. 1: 135 PSI
No. 2: 125 PSI
No. 3: 160 PSI
No. 4: 145 PSI
I re-adjusted the valves and did the compression test with the engine warm.
I installed a mild cam with a duration at .50 of 230 degrees and I was wondering if perhaps the valves should be adjusted differently than the standard 0.010 clearance. Should I use a different clearance for the exhaust valves and the intake valves because of the cam?
I was also thinking that maybe the compression chamber for the number 3 cylinder may be a bit different than the rest for some reason. The guy that did my head supposedly CC'd the chambers so it would have to be off a little to account for the higher compression.
Any ideas?
Should I do a leakdown test as well?
The readings are:
No. 1: 135 PSI
No. 2: 125 PSI
No. 3: 160 PSI
No. 4: 145 PSI
Any ideas?
