What should the compression be in a 74B engine?
It is an "L" engine which I always assumed had less compression thatn an "H" engine. I have one of those hand held compression jobbies that screws in the spark plug hole and has a guage with a pressure release button on it. It seemed to work well on the '67 so I am going to try it out tomorrow. I am not sure how good or reliable these suckers are.
My '67 is an "H" and has 170 psi in each cyl. I want to check the '74 but want to be prepared in case it is low. I don't want to be shocked or worried if it is.
Hi Guest!
