Awhile back the clutch slave return spring broke and I installed a generic spring which worked OK untill I got a new one.Installed the new one and after a week of driving I noticed that the pedal would only engage when pressing down about half way rather than the normal amount. I suspected a broken taper pin but that seemed odd seeing as a backup bolt had been installed in the crosshaft years ago! At any rate after taking a better look at the slave cylinder it seems I had installed the slave cylinder on the wrong side of the mounting plate. In order to correct this I had to disconnect the hydraulic hose which now necessitated bleeding the system.I didnt do the normal bleeding procedure(probably should hve) but went right to the method from the Moss video where you hold the pedal down,disconnect the pushrod ,open the bleeder, push the rod by hand to empty the cylinder,then close the bleeder to remove all the air from the cylinder. I couldn't seem to be able to push the pushrod in to bottom it out? Pedal still goes to the floor. How much play would there be in the crosshaft if the taper pin or bolt has failed? Should you be able to move the crosshaft 2"-3" from side to side? If I do have crosshaft issues will that cause an issue with the slave cylinder bleeding process? I'd like to be able to get the clutch functioning enough to drive the car across town to my garage and pull the trans there if necessary.Any advice welcomed. Karl
Hi Guest!
