twas_brillig
About two years ago I wrote AH Spares in England and asked if they had a collapsible steering column available; they advised that they could convert a supplied column to a collapsible for about $ 1500. I haven't pursued that any further or gotten any more details.
Marty Jensen of Jule Enterprises has a new (to me, anyway) product - a rack & pinion steering conversion for Austin-Healeys. Here's my notes from when I called him this evening(and I may have erred in my scribbles, so screwups are mine):
No real claims for safety when I called (he commented he hadn't done any crashtesting), but he advised that it's got two u-joints so there is a bit of safety increase here over stock (looking at the pictures on his web-site suggest that the column is still pretty dang straight). The steering column is from Ididit ( https://www.ididitinc.com/index.html ); the rack and pinion setup is Mustang II and all new parts; steering wheel position remains the same as stock. For the six cylinders, he provides a recored rad to be installed at a 28 degree angle for clearance as well as an electric fan; the steering column requires a MotoLita steering wheel or equivalent; you also lose your trafficator and gain a Chevy turn signal switch; the horn button remains stock and it appears that you could keep the trafficator appearance; the 4 cylinder Healeys don't need the rad mofication. The kit can be retrofitted to a complete car but it's easier with the shroud off; a bit of welding is required. If you look at the pictures he shows under 'Fuel Injected BN6' you can see the turn signal switch and the steering wheel hub as well as the rack and pinion setup.
So no intention to usurp the web-page info https://www.jule-enterprises.com/index.html , but figured I'd share what I thought was interesting. Marty also mentioned that he's installed this setup on five of the last six chassis that he's built.
Doug
Doug
