What oil do you use, and how cold is the engine? If you are getting close to the pour point of your oil (say within 20F), then a heater is almost a requirement. Some of those old diesels used straight-weight oils with pour points not much below 0F.kodanja said:In my old 1980 mercedes 240D I had a electric dip stick.
do ya think its a good idea to use that type of device prior to starting a TR?
Wow, thanks for the invite, Steve! The Stasbourg was already on my list of things to do, if I ever make it to PA again, but it will be good having the inside information.71MKIV said:You can come visit us in central PA and see live steam engines, and I'll even show you around the shop.
