T
Tinster
I have just installed a Flamethrower coil into my
standard everything 1969 TR6. Standard Petronix
ignition, standard carbs, standard plugs set at .025.
Dan Masters Power Block entire car wire harness.
I run the car on high test gasoline.
I read somewhere I need to make some adjustments
for the Flamethrower. What adjustment's, if any,
are recommended?
Thanks,
dale
are recommended?
Thanks,
dale
