KLUTZ
Well... I have started my 78 TR7 once in December, and again in January, just to warm it up and move it up and down the driveway. I havn't the last few weeks because of the bitter cold.
I went out today to give it a go. It is around the freezing mark today, so quite nice.
The car will not start. It turns over strong, but no go. I took the spark plug wire off of #1 and set it on the block... No spark. I took the wire from the coil to the distributor and placed it on the block too, and also no spark from it.
I checked all the connections, and they look tight, so... could the coil just die from sitting in the cold garage for a month or so? I have another one I can try in there, but is there somthing else I should try first? By the way, I leave the battery in throughout the winter if that makes a differance.
Thanks
Paul
Thanks
Paul
