Neo, I agree with Mark. Ever since I was a youngin messing with MGs, this has been characteristic of not only the LBCs but mostly of all cars. Unless you are dealing with a big block , big displacement engine then it might not be so noticeable. back in the old days if you had an engine that just was poorly tuned or had issues with the idle and run on after shutting it off, we would just depress the clutch just before turning off the ignition to keep the engine from running on or what we called dieseling. The drag on the throwout bearing was enough to stop the engine. An engine in good order and a good state of tune would minimise this run-on situation, but the drag on the clutch bearing was always handy sometimes.
Dave C.
