Hello,
I replaced/repaired the clutch system in my TR6. I also repaired part of the shifting mechanism that was obviously damaged in the transmission. Now that I have all the repairs done, I am able to shift into the different gears without depressing the clutch (while the engine is not running.)Is this normal? If not, what is most likely wrong? I don't know if it makes a difference, but I do not have overdrive.
Thanks, Kevin
Thanks, Kevin
