tomshobby
When I put my car back together I installed the clutch rod in the bottom hole on the fork shaft arm. I did that because of some physical problems that make it a little more difficult to push the clutch down.
When I did that the clutch pedal had to be pushed to the floor to disengage the clutch which made it more difficult for Shirley to drive the car. A problem because of her bad knee.
She is going to have a knee replacement this Wednesday and I thought I would try the rod in the middle hole to see if it might work for me and be better for her when she recovers to the point she can again use the clutch.
Finally the point: After a short drive I noticed the pedal free travel and distance to disengage were both different.
I have seen these hole positions discussed many times on the forums but have never really seen where anyone has had a good explaination.
I wonder if the different holes were put there for some sort of clutch pedal adjustment feature.
BTW, I think the change will work better for both of us.
Now it is time to go for a ride.
