clutch repair kit
There is a steel line that runs from the master cylinder to a bracket on the frame rail by the slave. Then the rubber line runs from the bracket/junction to the slave. It's been awhile since I had a ribcase transmission, but I think that hose is about right.
aahhh...probably that 3 ft long pipe i pulled out a month ago...was in the way ; )....still have it...it is 3 steel lines connected together with fuel line in a couple places..is this normal?
both ends are flaired with fittings....thx...zimmy
Fuel line runs separate. I can't remembar how the original lines run. It might have run with the brake lines, but certain it didn't run with the fuel.
no... i ment the 3 pieces of steel are connected together with fuel hose to make one piece..im guessing for flexability
