A recent inspection of the Clutch Master Cylinder in my BJ-7 revealed some fluid weeping, and although minimal, it could be causing problems with shifting. I now have to shift slower to avoid graunching on upshifts.
What's the best approach: shall I replace the MC seals or buy a new unit? Any suggestions or hints on replacing the seals and would it OKay to use emory cloth to prep the Master Cylinder bore rather than honing? Oh, and one last question, what's the proper application of the red seal grease that comes with the kits? Could it be applied on the internal seals, or used only on the inside of the dust cover? GONZO!
