Hi,
You may want to shop around a bit.
Girling MCs are very standard stuff and pretty widely available. The version with the smaller reservoir is used for both brake and clutch applications on a variety of cars. You might find it cheaper at non-LBC vendors. But $89(.75") and $99 (.70") at TRF or $80 (.75") at Moss USA aren't too bad. Also available for $99 (.75") at
www.pegasusautoracing.com.
There are other alternatives, such as the Wilwood .75" clone ($50 at
www.jegs.com and
www.summitracing.com). Some other manufacturers with similar MCs are AP and Tilton.
TR6 came with .70" clutch MC, but you might want to take this opportunity to go to a .75" bore (
please see recent Tilton Clutch MC discussion here). Your leg will need to work slightly harder, but you'll have taken one of the first steps to help correct some of the weakness in the TR6 clutch setup. Plus the .75" size is more commonly available and tends to be cheaper.
Assuming the reason you want to replace rather than rebuild is that the bore of the MC is damaged, you can also have an old MC resleeved, if you wish.
www.applehydraulics.com and
www.whitepost.com offer this service, probably others do as well. I haven't gotten a price lately, don't know if it's worthwhile for a clutch MC, but it can be helpful for NLA items such as the large-reservoir brake MC used on TR4.
