On the way home from Tahoe to Southern California last Monday (a great time was had by all!), my co-pilot and I noticed it was getting harder and harder to get the car into second gear (which is what we use to take off from a stop) and into reverse. This morning, I went out for a ride and by the time I got back, the car wouldn't go into first or reverse even after putting it in into a synchro gear then trying first or reverse, and second gear was not all that easy, either. The clutch is about a year old, has about 5,000 miles on it.
I was planning on having the car towed to the mechanic on Monday, but upon telling a friend about it, he stopped by, thought the linkage might need an adjustment and offered to have a look. On inspecting the linkage, he found the threaded end was BENT! The first 3/4 of an inch was straight, but then it took off at an angle! According to the catalog, there is a bend in the middle, but the threaded end is supposed to be straight. He's guessing that as it got more and more bent, the clutch got more and more out of adjustment, thus harder and harder to get into gear. He took it off, pounded it straight and replaced it so that the clutch is working in all gears again - that should get me to the mechanic without having to use an auto club tow. I've never heard of anyone else having this problem before; wouldn't you know the first time I did, it would be on my car!
Sharon
BN1 with 4-speed transmission
Sharon
