MGB Clutch line fitting
Lynn Kirkpatrick
Does anyone have a source for the 1/4" male flare fitting that goes into the banjo fitting on the clutch master cylinder? I can only find the tube with fittings at Moss, not fittings, only, unless I'm not looking hard enough.
All of the "current" fittings, or fittings on 1/4" tubing, have 7/16-24 threads. The banjo fitting has 7/16-20 threads.
Thanks
I haven't used them but I've seen it posted on other threads. www.fedhillusa.com shows british / girling brake line tubing, nuts and fittings.
GO TO NAPA, Lynn. Look thru their Bundy pipe assortment. :wink:
