clutch disk
rjc157
stupid problem but i can't figure which way the clutch disk goes on ,which side faces the flywheel ,have pics but don't know how to upload
Somplace on the disk it says "This side out" That side faces the rear of the car
On the disc that I am looking at. the splined hub protrudes more on one side. That side goes away from the flywheel. The other side is marked "Flywheel Side" but stamped so lightly that its hard to find. On some engines, the splined hub will hit the flywheel or crankshaft flange if you try to put it in wrong. Don't remember if that's the case with the Healey.
Marv J
Mine said "flywheel side" stamped on one side. I didn't notice any difference, sorry.
You certainly will if you put it in the other way around.---Keoke---- :laugh:
Funny, keoke, but I checked it several times to be absolutely sure I did it right!
