I replaced the clutch slave cylinder, and discovered that the master was leaking as well. I bought a rebuild kit from Victoria British, but I cannot seem to get the piston out of the bore. It is a '76 MGB. The Haynes manual says to disconnect the boot, and remove the clevis pin, then remove the clip, but I cannot seem to see how the clip is fitted in. I tried to remove the master cylinder completely, but the lower bolt is impossible to reach. The book says to go through the body access under the dash, but even from there it is a heck of a reach. Any suggestions on what I might be missing in either removing the clip or the cylinder?
Thanks,
Steve /ubbthreads/images/graemlins/hammer.gif
Thanks,
