2wrench
Okay, gentlemen, one more time on rheostat and dash stuff,
cause I'm there and kinda stuck.
First off, there is no trip to Rio, just wanted to get
your attention. I want to discuss Rheo, you know,
rheostats and dash stuff. Dang, this is a car forum,
not a game show!
Anyway, started hooking up dash stuff. Plugged in the
headlight switch; turned them on to see where I'm at.
My rheostat is suspect, becasue when I was driving the car way back when, lights dimmed brighter; then lighter, etc, untill next to no light at all. A red and black wire coming from the dash area that lights up the little plinth panel, when moved, changed the lighting somewhat, when moved
in conjunction with the rheostat knob.
I think the rheo has been going; going and now's gone.
Three wires red/white stripes connect the back of the
rheo. Made a jumper from those three to one and connected it to one end -- and then the other -- testing if I could
bypass the unit. Got no different result in either case.
Dash is loose and hanging in the "service position." Not all bulbs have been put in place. One or two bulbs might have previously been burned out or missing. Are things not
working because everything is not plugged in? Because bulbs
are burned? Because grounds are not happening?
Grasshopper is seeking advice from the teachers. What
do you suggest? Help me Obe Wan Kanobe, you're my only
hope.
not a game show!
hope.
