64rocksprite
Okay folks..
Once again, my poor storage practices many moons ago have cropped up /bcforum/images/%%GRAEMLIN_URL%%/wall.gif .
The cylinder head and water passages around the pistons are badly corroded, with chunks of rust visible. I've cleaned all I can reach, but that is not much.
Before replacing the water pump, I filled the engine block with a mild acid, let it sit for about an hour and then flushed with the garden hose. Lots of rusty water and some flakes came out.
Problem is..I have a newly re-cored radiator..I dont want to install it when surely more of this crud is going to come loose the first time the engine is up to operating temperature.
Anyone have any ideas on cleaning it SHORT of taking the block out and having it hot-tanked?
I thought about rigging up a 'temp' tank reservoir (bypass the radiator completely) that I could run hoses to and circulate a cleaning solution with the engine running to get it nice and warm. (?)
Open to suggestions!!!
Last one for tonight..this is a 64 MK II (downflow). I had always assumed that hot engine water exited the cylinder head at the thermostat housing, thru the rad, then returned at the bottom hose..is this right or do I have it backwards? Looking at the water pump, seems like it might go the other way..I'm going to install a elec fan..and want to get the sensor at the inlet. I would imagine the stock temp bung is at the hottest point, after the t-stat.
THANKS ALL!!
Devin
THANKS ALL!!
Devin
