G
I haven't driven my car much in the last 8 months but notice an unnerving noise that sounds like it's coming from the front of my short block on startup. A clanking noise. Seems to go away after warmup and not real obvious when driving. Up she goes in the air this week, pull the pan and see what I can see. I did notice that my thrust washers look like they are going or gone. The ole push-the-crank-back-then-engage-the-clutch trick shows visible movement. Not good. I will stick a dial gauge on it and see. Not sure what I can see peering into the bottom of the short block with a strong light but will check all bolts and look for anything else that might be going on. Would be great it if is only a header rubbing, don't know. Not in the mood for major work.
